Coilover question
Coilover question
Has anyone used the Kw's for the F-body?? Pros cons?
or has anyone found a good stiff spring/strut combo..
I really want coilovers to adjust the height and the damper, but they are so damn expensive.
There are a few members in here that use KW but they are far and few. Sam Strano sells KWs and can give you more info about them.
I currently use ground control coil overs with bilstein dampeners. So far have been very happy with them, it has been 2 years. There are a multitude of spring rates available especially for the front. The front uses the universal coil over springs that any circle track retailer would have as well as eibach, h&r etc.
LS1TECH Sponsor
While true, there are other issues to consider.
1. Running a GC setup on Koni's requires work and some modification to the Koni to fit them. That can be a pain and would technically void the warranty vs. a KW V3 that's a setup system with a full intact warranty.
2. KW V3's are independently double adjustable, like Koni DA's.... but again there is the warranty thing. And Koni SA's are what save you some bucks with a GC setup, but then you don't actually have the same type damper (now you are comparing SA Koni's to DA KW V3's.
3. I use a lot of V3's on Mustangs, they rock. I've used some on Camaro's, but to be honest with the older car folks tend to want to buy less expensive parts. I've sold a few sets of V3's to F-body owners, and all have been happy enough. But it's a limited market as the cars get older and cheaper the folks buying them tend not to spend $2k on suspension parts being younger and sometimes a little idealistic about how well cheaper stuff works.
__________________
Thanks for the info!
I'm going to look into the site, the price is better then anywhere else for the Kw's and I want a true coilover.
I also like the fact I can drop the car more then a spring can
What would you say about this set up, IAS Coil-over/shock kit... as far as handling and lowering the car?
I've been looking at the AFCO set-up lately. They have a set-up out that was installed in a GMHT mag that seemed pretty nice. I called AFCO and they said their coilover can be had in DA @ $300 apeice.
LS1TECH Sponsor
Those shocks are non adjustable, and not in the same damping league as a Koni or KW. Also, that kit doesn't have any rear springs or weight jackers included. And Edelbrock doesn't even make a kit so you end up piecing stuff together while costs are rising. I sell IAS's, because it's option I need to offer... but it's not one I recommend.
__________________
LS1TECH Sponsor
Further, you will find KW's on handling applications around the world. From the Dodge Viper ACR/ACR-X to cars that have won the 24 Hours of the Nurburgring.
__________________
LS1Tech Premium Sponsor
I have KW V3s on my 2005 GTO. They are simply excellent for a track/street shock. They are certainly more focused for a road racing setup that can be driven on the street, rather than the other way around - making them ideal, IMO.
While different than the F-Body setup mostly in fitments and internal design, they share the 19 settings for rebound on the top of the shock and 14 settings for compression located on the bottom. This gives you 266 possible options for shock settings, which means they can be difficult to dial in. But, this is GREAT for a road racer looking to get the car to really stick and not be agitated by imperfections in the track surface and rumble strips.
Once I got my car dialed in, I left it that way because I just wanted to go home after I unloaded the trailer. I haven't touched my settings since. In other words, I kept them on the track settings for the street. I have spoken with a few other guys who started using my exact settings and love them.
The KW coilover setup is something I will install on all my performance vehicles. They have an absolutely great reputation throughout the racing world, Europe, and slowly gaining steam in the US. The stainless bodies are sharp looking, too. We can sell them as well.
LS1TECH Sponsor
I do not. Here's the deal. To run a coil-over on a Koni, it requires modifying the shock... and that voids the warranty. Are there kits to do it? Yes, there are. Do they work? Yes. Are they a pain to install on the fronts? Yes.
I used to sell kits like that for Koni, but between folks not understanding how to do it, and the companies being a pain in the *** to deal with.... and the fact that I made my springs based on the spring rates and height I found worked best for handling on less than pristine surfaces, it kind of made it redundant.
__________________
Wow, thanks for the answers.. I really think the Kw's are my best be though expensive, I won't have to mod the setup and they come with a lifetime warranty, even better and the more height, rebound, etc. adjustments make them more appealing.
LS1TECH Sponsor
Expensive? Certainly compared to say a set of Bilstein's. Not so much compared to even a nice set of headers, or even really good tires.
You'd be silly to put these on a car you don't like, or won't keep. Doesn't make sense.... but it does make sense if you are really trying to get a premium product on the car that will do a number of different things, and do it without hassle.
__________________
LS1TECH Sponsor
I agree, completely.
__________________
Hello Sam, I have been following this thread and really appreciate the information. I am also considering a coil-over set and was wondering if there was any other setup worth considering other than the KWs? At least for a 4th gen camaro? Street/autocross
Again, thank you for your opinion and time
LS1TECH Sponsor
Not really.... I mean you have drag race kind of shocks and springs which don't work nearly as well as a good set of shocks like Koni or Bilstein and good springs. Edelbrock has a "coil-over" setup but it's got some issues. It's front only, doesn't even come with rear springs let along rear height adjustment, and the shocks aren't adjustable for damping at all.
__________________
