mini tub questions
i have a 94z and im putting in a wolfe mini tub. i have 15x10 greg weld rims with 7.5 bs what is the biggest tire i can run without rubbing i have 28-13.5-15 will these fit without spacers.
and i have qa1 coil overs will they still fit with the mini tub..
as far as i know the wolfe tubs dont touch the spring area. i think somewhere on here they were talking about a 30x11.5 tire??? dont quote me on that though. why not just go with a regular tub? the wolfes still use the factory outter wheel house limiting tire hieght.
https://ls1tech.com/forums/drag-raci...ed-15x12s.html
check this thread out looks like a 325 is a tight fit and a 29 inch tall tire cuts close with the factory outter wheel house.
summit and jegs i know, i just bought some 40" sheet metal ones from summit i think its another 20 bucks for aluminum ones. you cut out the whole wheelhouse all the way to the quarter panel skin.
there are a couple good build threads on here from some of the guys doing it ill have to try to find them and post them here. if mngmp ever gets back up and going ill start a step by step build thread on there for the 94 camaro im going to be doing here soon.
