SJM line lock help
In the instructions it says to drill two holes to mount the line lock on the shock tower. With the way the lines are bent/long you end up practically right against that ground stud on the drivers side. If for some reason the line or the solenoid itself ends up toching that ground will it cause any problems? I can push it toward the engine about a quarter inch but it puts tension on the abs module some. Thanks
Thread is a bit old but I ran in to this problem also. I started my own thread on the problem and what I had to do to install my top mount system.
https://ls1tech.com/forums/suspensio...l#post16718385
