What Shocks To Use???
If you're stuck on Eibach's, you can get Bilsteins or KYB's for cheap.
As it was said already, it depends on your goals. Daily driver or weekend warrior at the track? How much do you have to spend? If you have about a grand, go with koni's. If on a budget, Bilsteins or KYB. it all depends. You need to provide more info than "eibach springs".
From what I hear the Strano springs have amazing spring rates and ride great but don't drop you as much as the Eibachs, so I guess it's what you want. The Eibachs are still great, you can't really go wrong either way if you're not tracking the car and just want improvements in handling/looks.
To answer your original question, KYB AGX's (which are adjustable) and Bilstein HD's and Bilstein SLP's are in your price range.
The AGX's are adjustable from 5% below stock damping to 23% above stock damping value. The Bilstein's are non-adjustable and considered an all-purpose yet good handling, moderately high quality damper.
Koni's are considered the quality and performance leader among mainstream brands but are also approximately twice the cost.
SLP/Eibach/Bilstein has a pretty popular matched set if you don't have your Eibach's yet... ~$675 total
ramey
I also sell shocks. AGX, Bilstein, Koni, Tokico..... If you are trying to do this on a budget than I'd recommend a set of SLP Bilstein's. I have those in stock for $379.99/set. For me, there is no way I'd run an AGX over a Bilstein on a true street car. Bilstein's work better and are more durable too.
Local pep boys have a set of 4 eibach springs for 200. I was looking for a set of a shocks now. 200-300 a set, ones that will work best with eibach springs. I really like the drop it gives, not trying to lower it alot, just about a 1 to a 1 1/2 drop or so.
ramey
That looks similar to a strano spring stance.
His Fquick Pro Is DJSanchez.
http://www.fquick.com/garages/djsanchez2/6875
He states it is a pro kit, but didnt mention the shocks.
