Benefit of UCA swap?
I'd like this but I've never asked if it's daily drivable:
http://www.cortexracing.com/store/su...3-2002-camaro/
I've had the GW del-a-lum UCA's for years in my daily driver and the only problem I've had is that the heads of the bolts damage the dust cover where it attaches to the spindle. I don't recall noticing a differences other than the ability to dial in more caster and camber. Your alignment will dictate your tire wear. If you don't need the additional alignment range say for autox/RR/HPDE, then decide how much you like swapping UCA bushings. If not very much, then I'd recomend a UCA with del-a-lum. I would prefer a heim joint but my concern is NVH in a daily driver.
If you still want a set then UMI has a set w/poly bushings that'll work good in that location, and they have already addressed the compression travel issue on there UCA, and there only about $162 right now, just about $20-$40 more that upgrading the factory UCA's with the GW del-a-lum bushing kit.
I spoke to Filip at CorteX a while back and asked about this setup. The upper arm is relocated down low to have the correct geometry to package the upper arm inside the wheel for much increased tire clearance. Obviously the OEM spindles are eliminated and the Cortex Radial X drop spindles are used. This is great because the factory wheel bearings in these cars are a major weak point. I believe the upper arms are also available with rubber/poly mounts for street use.
https://picasaweb.google.com/cortex....eat=directlink
That car in the picture belonged to Randy MacIntosh. It's since been destroyed in a wreck last year. He mentioned that he picked up 3 seconds at Sears Point just in changing to this suspension.
Mostly people who auto-x and road race with 315 front tires.
