vibration from rearend..someone help please
I bought the car lowered and from st louis and i did alittle.But i really noiced it when i put the 315s on and i have a lot of road noise also.....also it has a 8.8 ford rearend. i do plan on doing a adjustable panhard rod very soon
315's will increase ride harshness, and noise. I suspect Ramey is on the right track though. Start by check that pinion angle. An unbalanced driveshaft, u-joint wear, or both will also cause vibration.
