How does this pinion angle look
Old Jan 8, 2012 | 06:20 PM
Valkyn's Avatar
Default How does this pinion angle look
Finally pretty much done with my 9" and full rear suspension install
I set the pinion angle to be parallel to the drive shaft angle, per the instructions I got from talking to UMI. The angles are parallel as measured at the flat spot on the bottom of where the torque arm mounts to the rear and the DS near the rear end.
It seems to drive fine but the front of the torque arm seems to be pushing up on its poly mount pretty hard, as seen here:
I have the reloaction bracket set in the holes that are third up from the bottom, which is what UMI also suggested.
So does this look okay? Am I doing something wrong?
Old Jan 8, 2012 | 06:59 PM
1lejohn's Avatar
Is the frt of the t arm nose up ,down or neut. in the front mount ? I have mine nose up alittle in the frt. mount and then basically neut, or zero with the drive shaft on the rear. You could raise it up one hole in the front. Looks good in the rear. I think of the torque arm like the rear control arms you want it at a small positive angle in the front mount and a zero or neg 1 degree down in the rear.
Old Jan 8, 2012 | 08:02 PM
UMI Sales's Avatar
Hey Valkyn. Thanks for choosing UMI. Your driveline looks pretty awesome. I liked the pic of everything bolted together on the floor.
Denny's Driveshaft? Good choice.
Who built your 9"?
As you add poly bushings, etc. you can minimize pinion angle as you've done. Rubber bushings need a degree difference so everything goes to zero under acceleration.
You should be good to go on the rear as you have it set. If you get any wheel hop or other weird issues, you can put it a degree nose down.
Agree with 1lejohn, if you can move your biscuit up a hole, go for it. Were the pics taken with the suspension fully loaded? Raising the nose a bit, or at least relieving the pressure, will add a bit more instant center which will help forward traction.
Your relo brackets sound fine. Once again, if you need more forward traction you can lower the arms a hole, then try.
Let me know how it looks after you move the front up a hole.
Did you like how it felt with the new suspension and rear?
ramey
Old Jan 8, 2012 | 08:22 PM
Valkyn's Avatar
Hey Ramey...Was it you I talked to about setting the pinion angle?
Yeah its a Denny's DS...I figured that nothing else on the car was light so I might as well go for a bullet proof setup. I bought a moser housing and axle package and had the center section setup at a local shop and did the rest myself. The POR-15 paint came out great.
The pictures are taken with the suspenion fully loaded...heres a pic:
The jack is just there for safety...all the weight is on the jack stands.
It feels good on the street so far. The spool makes it abit interesting on low speed corners but feels very solid.
Maybe you could tell me how to set the drag sway bar? I have the links connected but not tightened...How tight should each side be?
Old Jan 8, 2012 | 08:28 PM
laytoncamaroz28's Avatar
I may be very wrong but is your torque arm upside down? I have mine mounted the exact opposite
Old Jan 8, 2012 | 08:55 PM
Valkyn's Avatar
The adjustment turn buckle is down, so I assume its right.
Old Jan 8, 2012 | 08:58 PM
02_camaroz28's Avatar
If you have the same UMI torque arm as the one above yours is upside down cause OPs is right Lol Otherwise its probably the difference in companies. Some have the top bar coming down and some have the bottom bar coming up.
Old Jan 8, 2012 | 09:04 PM
Mines a bmr and it's with the long side down and the turn buckle dowm
Old Jan 8, 2012 | 09:14 PM
UMI Sales's Avatar
Ours should have the solid tube up and the "butted" tube down. Also, turnbuckle down. And yes, different manufacturers can be different.
For the drag bar, at ride height with driver in car, the end links should be set neutral. From an engineering standpoint it's best to minimize the number of turns out so the maximum threads engage in the adjusters. Basically if one end link is installed and the jam nuts tightened, the other end should slip right on when everything is neutral. If the car leaves crooked, one way or the other, you can preload the bar. If the car darts right on launch, lengthen the passenger side endlink one turn then repeat the test. This testing may require multiple evenings at the dragstrip...
ramey
Old Jan 8, 2012 | 11:03 PM
Valkyn's Avatar
Thanks Ramey.
I already have the LCAs in the bottom hole (with the LCA lower brackets)...should I have started higher?
Old Jan 9, 2012 | 07:47 AM
UMI Sales's Avatar
Hey Valkyn.
There is really no particular negative effect to running the bars in the lowest hole on a mid powered street car other than potential roll steer. If you use them in a handling application (i.e. autocross, road race, etc) it can make the car oversteer a bit. Lower trailing arms parallel to the ground at ride height tend to minimize roll steer.
Also, as you increase power and traction, having the bars at the lowest holes can make the car hit too hard on launch and potentially unload the rear tires.
Let me know your thoughts.
ramey
Old Jan 9, 2012 | 08:11 AM
Valkyn's Avatar
Thanks, I guess ill keep them where they are at for now. Will just have to drive it more and see how it feels.
I have a boost ready 385 engine waiting to go in with an F1A procharger when I get the money, so other than tweaking the settings abit I think the rear end and suspension are all ready for the power.
Old Jan 9, 2012 | 08:17 AM
UMI Sales's Avatar
I'm liking the sounds of this project. Agree, you have an awesome suspension baseline and it appears you've done your homework. Let's keep this thread going with how your car is driving and we'll get it perfected. Then you can add boost. Yes!
ramey
Old Jan 9, 2012 | 09:06 AM
Valkyn's Avatar
In the mean time I have an NX kit thats going in too lol...multiple stage project.
Would you recommend raising the LCAs up one hole to get them closer to parallel? I don't autox or anything, just street driving and track duty.
Thinking raising them a hole might relieve some of the stress on the poly mount in front also..
Old Jan 9, 2012 | 09:23 AM
UMI Sales's Avatar
Hi valkyn.
If you don't have forward traction trouble now, it wouldn't hurt to raise them so they're closer to parallel. If you end up with too much wheelspin or wheel hop you can always lower them back down. I think up a hole would be worth a try.
Do you have holes available on the front mount?
ramey
Old Jan 9, 2012 | 09:35 AM
Valkyn's Avatar
Yeah it can go up one hole in front.
If I move the LCAs will I have to reset the pinion angle?
Old Jan 9, 2012 | 09:56 AM
UMI Sales's Avatar
Hi Valkyn.
LCA's should not affect pinion angle. Moving the front mount up a hole would usually change it but since it's in a bind, it might not.
I would still check the pinion angle afterward and make sure it doesn't go past zero to the plus side. It should always have at least some pinion angle in it with everything at ride height so that under load it never goes positive.
Let me know what you find.
ramey
Old Jan 10, 2012 | 08:17 PM
Valkyn's Avatar
Alright I moved the LCAs up a hole and moved the clam shell at the front up to the top holes. The front seems to be in less of a bind now.
Moving the front moved the pinion angle up abit, so I readjusted it. Set it with the pinion about half of a degree negative of the drive shaft.
With the suspension loaded the LCAs are right around parallel to the ground, my digital angle finder said they were 2* up in the rear. Would I be better off going back to the bottom hole?
Old Jan 11, 2012 | 08:24 AM
UMI Sales's Avatar
Hey Valkyn. I took another look at your pics and just realized the little aluminum square on your trans mount needs moved from right to left. That's whats squishing your bushing into a funny shape.
As for the trailing arms, they should be pointing downward toward the rear when the suspension is loaded. With a fabricated 9" and there not being an industry standard for those adjustment holes, just do whatever you need to in order for the arms to be pointed down toward the rear. We have a ton of customers who automatically use the bottom hole on our relocation brackets with great traction and no troubles. I'd say the bottom holes would be fine.
Let me know how the plate swap makes it look. I have a feeling it's going to be better.
ramey
Old Jan 11, 2012 | 09:12 AM
1lejohn's Avatar
Originally Posted by UMI Sales
Hey Valkyn.
ramey
Good info. It will also over steer on the street with drag radials and the arms in the lower hole. I found that you can actually run the rear control arms frt end down or neg. to increase handling. Mine where set up that way before I installed the relocation brackets. They tend to do this naturally on lowered cars. Still waiting to order my drag bar busy buying FFA animals for my kid.
We have cut 1.4's 60's with the stock rear bar in place. The car launches straight but twists bad if the frt bar is removed. Trying to hook on 18" drag radials now. So ording one soon.
