The not so expensive secret to elliminating wheel hop!!
I just installed a tunnel mount ta to get it off the tail shaft and want to install a poly mount on trans went to es web site and they dont even show poly mnt for these cars what pt num are you guys using.
I really have no idea why poly mounts are hated. I had used them on 2 cars over the past 5 years. They have a little bit of vibration at first, but they soften up after a few weeks to feel like stock, but stronger. It most definitely helps the feel when shifting wide open. The problem is people put them on, and immediately remove them and then come bash them online. I would like to see proof of a poly trans mount busting a transmission tail shaft while on rubber motor mounts. I have yet to find this myth proven.
I'll always use poly mounts.
must be nice guys... My transmission mounts for a c6 are around 290$... and you guys can get them for 30$..... Damn vette tax!!! http://www.westcoastcorvette.com/p-1...5-2012-c6.aspx
I did the complete suspension kit 1st & now ive got the poly trans & motor mounts You can feel the pebbles in the road lol If youve got vibrations it will magnify them But its way better than stock I pulled the suspension off my v6 firebird & put it on the T/A & other than road grime they looked new after 20k The bird would do 85mph before the install on a certain curve After wide open at 110mph I also had nitrogen in the tires Love that **** too I give Energy Suspension 2 thumbs up Cant wait to see how my 32mm front & 25mm rear act bet it wont roll or flex
#35
Polyurethane is prone to cold flowing, where it changes shape over time -- that is what must be meant...
Cold Flow
Definition: The distortion, deformation, or dimensional change which takes place in materials under continuous load at temperatures within the working range (cold flow is not due to heat softening). See also CREEP and COMPRESSION SET.
Cold Flow
#36
Funny thing about this thread, I have had about seven fourth gens and not one of them stock or modified has ever wheelhopped once..... Ever!! I don't get why people have this issue. Hard launches, soft launches, various road types and conditions. It simply never happens.
Weird
Weird
#38
Pontiacerator
Funny thing about this thread, I have had about seven fourth gens and not one of them stock or modified has ever wheelhopped once..... Ever!! I don't get why people have this issue. Hard launches, soft launches, various road types and conditions. It simply never happens. Weird
A bad tranny mount will cause the whole driveline to go spastic on a hard M6 shift. I replaced mine with a stock rubber mount and it's been 100% fine since.
#39
I had the energy suspension for about 250 miles and hated it with poly MM's. my b uddy has the prothane and its much better and the poly is noticeably softer. i wouldnt mind his but my poem rubber one lasts me just dfine with spirited driving so why not just go that way
