Black rotors anybody? (PICS PLZ!)
Which Wilwood (4 piston?) fixed caliper set up/number is that in the pic above, and what is the diameter of the Stop Tech rings you used to fit inside an f body 17" SS wheel?
Did you ever run those slotted EBCs on the front, and if so, how did they hold up to open tracking with a harsh 'track pad' (stress risers/cracks/etc.)??
Q2: The calipers are Wilwood W6A Caliper 6-pot upgrades for a C6 Z51. (PN 140-12629)
Q3: One small correction: those are Racing Brake 13.4" rotors, not stoptech (my bad). I was able to fit this brake setup on my 2nd gen because the 4th gen 17" wheels require a 2" spacer to get the correct backspace. The barrel of the wheel has a larger diameter, starting a couple inches away from the hub mating surface (inside face) of wheel. The 2" spacers happen to align the caliper and rotor with the wider portion of the wheel. Without the spacer, the caliper will contact the wheel. My setup would most likely not fit on a 3rd or 4th gen F-Body without the wheels sticking out of the wells.
This issue does not happen with 4th gen corvette 17" Sawblades, fwiw.
Speaking of checking, risers, cracks, etc... I pulled the RB rotors about two months ago, due to surface checking and worn out pads (Carbotech 12). The rotors still have life in them, but the pads are done. I got four and a half track days out of them, 4 @ Gingerman, .5 @ Road America, plus a handful of auto-X events.
I currently have Rock Auto blank C6 Z51 rotors on the front, with Wilwood BP-20 pads. I haven't abused the setup at all yet, so can't say much for longevity, but the cost per track day seems favorable. The rotors were $120 delivered, compared to $700.
No, you misunderstood. It's stupid, not different. IT'S A FRICTION SURFACE. It cant stay "colored" when its responsible for stopping the vehicle. What you're wanting doesnt exist, at least not on a commercial level. And no im not sorry if it hurt your feelings, I was giving you honesty, whether you liked it or not.
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
