Cheap Lowering Springs?
I'm about to purchase some c6z06 wheels, 17x9.5 Front and 18x10.5 Rear. Tires will be 275/40 up front with 285/35 out back for now, I plan on upgrading the rear tires to a 315 later on. I'll most likely be getting adj lca's AND the relocation brackets. Adj panhard bar will go on when I get the 315s to assure that the rear is centered! Now, I would like to lower the car a little bit so there isn't so much of a gap between the wheels and fenders, but I want to go the cheap route on springs for now..
Where can I get a set of 4 that won't break the bank?
Would I still be able to fit a 315/30 on a 18x10.5 wheel being lowered 1-2"?
You need an adjustable panhard bar to lower the car properly and keep the rear end centered (or you can custom make one, if you're handy). This is especially true with 285 tires. Even with the bar you're likely to rub on the rear outer fender lip and seriously damage your tires. You should be prepared to roll the fender lips to do this safely.
LS1Tech Premium Sponsor
Give us a call here and we can price out a set of BMR lowering springs for you. Here are a couple picture of our customer's cars with BMR lowering springs installed.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
