Loud Whine when turning ?
Old 03-20-2012 | 02:24 AM
UAE_Z28's Avatar
Default Loud Whine when turning ?
Why do i get a loud whine whenever Ii press on the brakes and turn to the right at the same time? it happens usually when I'm coming up on a 90degree turn.
The thing is it only happens when i press the brakes and turn to the right, doesn't happen when I turn to the left. Could it be a rod issue? when on the highway the car pulls to the right.
Any help is appreciated. Thanks.
Old 03-20-2012 | 11:27 AM
chadroosa's Avatar
Check your front hub bearings for play and noise
Old 03-21-2012 | 03:13 PM
Nathan C's Avatar
Your power steering rack could be leaking. Chech for puddles in the driveway and check your fluid level.
Old 03-21-2012 | 10:28 PM
SOMbitch's Avatar
This. You have a worn out hub it sounds like.... pretty classic symptoms....
Old 03-21-2012 | 11:43 PM
VinR1's Avatar
I'll ask
Roughly how much does a pair of hubs cost and can I install them in my driveway?
Old 03-22-2012 | 11:00 AM
chadroosa's Avatar
Timkins are around 130 a piece and yea pretty simple job..
Old 03-23-2012 | 10:59 AM
UAE_Z28's Avatar
Thanks guys i'll give it a check tomorrow.
Quick Reply: Loud Whine when turning ?
