want to lower car 1.5 inches 2002 TA
i have a 02 TA that i want to lower 1.5 inches all around.
looking for good handling and a decent feel.
What spring and shock combo do you guys recommend?
If you want to experiment you can order springs with your own custom springs rates from some dirt track/oval racing sites, you can also go with something that is already proven like Strano springs, (with multiple national auto-x wins). Hotchkiss is also a good brand, although may not drop you as much as you want.
As for shocks, best bang for the buck street shock is Koni SA's IMO. Rebound adjustable, good quality, lifetime warranty and down right ridiculous handling, superb neutral balance and feel (think german sports sedan).
Cheaper (although not as good) options are SLP / HD bilstien shocks (non adjustable, don't offer the rebound or handling that Koni does, but good quality), or KYB AGX (adjusts rebound and compression with the same ****, won't offer the ride/handling compromise that Koni does because of how they adjust, and have iffy quality).
If you want to spend a little more you can look into custom valved race bilstiens or Penske shocks as well.
edit: also stay away from drag shocks like QA1, Afco, Strange etc. as you will be paying to hurt handling, ride and feel.
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
For the immediate future we are just doing the Springs first just to see how that feels.
this car will NOT be going to any tracks (1/4 or road course) its a street driver with short WOT blasts from time to time.
the spring change is being done mainly for aesthetics.
at the top of the springs list are
1- Eibach -3870.140 - http://performance-suspension.eibach...ookup_products
2- BMR - Spoo1 - http://bmrsuspension.com/?page=products&productid=291
3- ??????
keep the suggestions coming guys
Thanks.
3- ??????
Thanks.
Strano springs I'm sure are good. But they are performance oriented. Every picture of them I have ever seen, and hundreds of people have complained about how the front end of the car appears to sit higher than the rear. On top of the fact that most people install them and the next thread is about how they can get there car lower because it's not appealing to the eye. Like I said, performance oriented. Regardless of weather it does or not is not the issue. The op is looking for an appearance mod and the pro kit without a doubt, no questions asked will give him what he's looking for.
What exactly have you read about them? People complain because they are a progressive rate spring, but other than that what draw backs keep you from buying them? I only ask out of curiosity because I loved mine. The LS kit sags in the rear. That why guys most often run the LT kit. I did and ran bilsteins with them and it was perfect for my dd with a budget. On the other hand my buddies z28 with a LT pro kit and koni sa's handles like it's riding on rails along with the other suspension mods he had done (sway bars, subframe connectors, ect). But the pro kit gives the look too. Just curious to any insight you may have that I've over looked or not heard of.
Doh I was wrong, I have the bmr spring on my firebird. I love them
Eibach:
![](http://i758.photobucket.com/albums/xx229/sayaben/9aa865e9.jpg)
Bmr : The spring rate is firmer however that does not compromise ride quality, it infact makes it better. Where the eibachs fail is that they compress too far, the bmr springs give more response to the vehicle going over a bump. So the spring initially reacts softly but then as it compressors further it will get slightly firmer
Bmr:
Eibach:
Bmr:
![](http://i758.photobucket.com/albums/xx229/sayaben/9fa1c3de.jpg)
Eibach:
Bmr:
Eibach:
Bmr:
I think you may have your information wrong. The bmr springs are a linear rate spring. The amount of pressure it takes to compress the spring one inch, will be required again to compress it another inch. The eibach is a progressive rate spring. That means that as you compress the spring, more and more pressure needs to be applied to continue compressing it as opposed to the bmr which doesn't.
I'm in the same boat as you OP. I love Stranos, but like you I want that extra measly 1/4 inch. B&G is probably the route I will take. If Mr Strano would ever come out with a 1.5-1.6 inch drop spring, I'd be first in line!
He won't. Yet again, for the same reason. His springs are designed for performance and not appearance. The reason his springs lower your car at all it's because of center of gravity. The reason he won't make them any lower is probably because the length of travel will be reduced to a point in which shocks can't really control the spring for the type of competition driving he build his cars for. If you want performance, with some appearance get his springs. If you want appearance, with better handling go else where.
We went with the Eibach Pro kit.
the car looks great and handles good
BUT
on one dip on the HWY one of my rear tires touched the 1/4 (i think left side)
i am using Monroe shocks which i want to replace with adjustables.
My thoughts are that if i can slow the rate in which the car comes down it wouldn't touch anymore.
What do you guys think?
also like some of you guys suggested the Konis are at the top of my most wanted list.
Please advice,
thanks
David
BUT
Please advice,
thanks
David
BUT
Please advice,
thanks
David
BUT
Please advice,
thanks
David
