Front Shock Mount Assembly
Old Mar 31, 2012 | 08:58 PM
billscamaros's Avatar
Default Front Shock Mount Assembly
'99 Z28 M6 -
I'm replacing the front suspension in my car ... it's a high mileage car, so I'm replacing everything. I bought new springs, new shocks and new shock mounts. I want to pre-assemble the shocks/springs prior to tearing the old ones out.
Does anyone have a good diagram of how the shock mount is assembled? Specifically - there is a rubber isolator/bushing that looks like it fits into the top section of the shock mount.
How does this fit into the shock mount? Is it compressed under the nut on the top of the shock & shock mount.
Thanks
Bill
Old Mar 31, 2012 | 09:21 PM
jsteele90's Avatar
Yes ht goes on top the shock mount and the nut for the shock is tightened down against it. That isolator is extremely important!
Old Apr 1, 2012 | 01:53 AM
TruBloodTransAm's Avatar
From bottom to top....
shock < spring isolator (on the spring perch) < spring < big washer on the shock shaft < shock mount < shock mount hat (pictured above in the first post) < nut
Old Apr 1, 2012 | 07:00 AM
LS1HIGHLIFE's Avatar
Dont forget to use antiseize on the parts so thy don't corrode and stick together. Also there is a rubber grommet for the upper control arm that may need to be replaced.
Old Apr 1, 2012 | 07:30 AM
Thanks for all of the input! One side of the shock mount hat/isolator is concave. That is the side that goes up, and the nut & washer fit down inside of it?
Old Apr 1, 2012 | 10:52 AM
Yup, that's right. I wouldn't use a lock-nut, just a regular nut and lock washer and possibly a jam nut. The material in the lock-nut will get tight and want to spin the strut's shaft. A regular nut negates this.
Old Apr 1, 2012 | 01:32 PM
Ok .... last question ....
I'll orient the shock mount-to-tower bolts with the two lower shock mounting ears.
Otherwise, there aren't any other adjustments on the shock/spring assembly that I need to worry about, right?
Old Apr 1, 2012 | 06:24 PM
Assembled like this?
I know that I'm supposed to torque that nut on the top, but I'm not exactly sure how to do it. The nut tightens down using a wrench and an Allen wrench.
Old Apr 1, 2012 | 07:04 PM
Darker Shadow's Avatar
That should just tighten down with a wrench. Having done the exact same thing last night and this morning it happened to take two people to do that for me. One holding the Koni in place where the adjustment would be in sight while holding the bottom of the shock in place and top shock mount in place, and the other with the impact driving that exact nut down. I guess I'm not understanding what the allen wrench you mention is for though....
Old Apr 1, 2012 | 07:32 PM
The end of the shaft coming up out of the shock is set up to take an Allen wrench. I assumed that it is used to hold the shaft in place while tightening the nut down. I'll try to use a Torque wrench on the nut. Thanks.
Old Apr 8, 2012 | 06:02 PM
TeeTopZ's Avatar
Did the "big washer" on the shock shaft under the strut mount come with your shocks, or did you have to purchase it somewhere else?
Old Apr 8, 2012 | 06:27 PM
On my Konis that big flat washer came with them. It was about 2 inches in diameter.
Old Apr 9, 2012 | 06:00 PM
The Bilsteins came with a big washer (it's kinda a cup, though) but I didn't see where it fit in. It's not currently in my shock mount/spring/shock assembly. You're saying that this fits UNDER the shock mount, on the shock shaft, between the shock mount and the shock body? What holds it in place?
Old Apr 9, 2012 | 06:13 PM
You're making it too complicated. This is a picture of my Koni shock, notice how the washer just sits flush up against the bottom of the shock mount. It's sandwiched in between the shock mount and the shock itself. Not sure about the Bilstein washer, but I assume it fits the same way.
Old Apr 9, 2012 | 07:10 PM
My shock assembly is slightly different in that the shock body isn't as close to the shock mount. Which is why I ask how the washer will stay in place.
This picture is my assembled shock, spring and mount assembly, with the washer leaning up against the spring.
It looks like the washer would fit up under the mount, but I'm unsure what the point of having it there is?
Old Apr 10, 2012 | 04:05 AM
94FBIRD's Avatar
Bill, the large cup gets lightly hammered down around the shock body. It contacts the mount should you bottom out the shock. You'll need to take the assembly apart again remove the lower spring cup, tap the cup onto the top of the shock body and then put it back together. And yes, the allen wrench end is used the hold the shock while you tighten the mounting nut.
Old Apr 11, 2012 | 12:01 PM
428 78T/A's Avatar
Well I didn't put mine back on. The torch used to get the top nut off completley destroyed them. Put 400 miles on and no problems.. Yet..
Old Apr 11, 2012 | 07:20 PM
So I have the front end almost torn apart. Is there a trick to getting the lower control arm off? Specifically the rear bolt that runs vertically .... it doesn't want to come out. I want to ask here on the forum before I beat the thing out with a hammer!!!! And the forward one that runs horizontally seems to be blocked a bit by the power steering rack. I'm assuming that the first is just rusted in, and the second one just needs to be worked around the rack. Right?
Old Apr 11, 2012 | 08:00 PM
94FBIRD's Avatar
See this thread for what IS going to happen to your car.
https://ls1tech.com/forums/suspensio...ened-here.html
