Best and strongest subframe connectors ?
#123
LS1Tech Premium Sponsor
The MWC design is the simplest, most effective(short of the thru-floor design), and is a true subframe connector. The LCA box is NOT the subframe, nor is the front floor cross brace. Also I am a firm with the statement that any bolt-on suspension or chassis component that is designed to increase rigidity will flex and/or move well before it does it's intended job. More is not merrier.
