How does this alignment spec look?
I will however say I completely agree with the toe and caster issues. He's definitely got it set too far outwards. I usually set it .01-.05 degrees toe in so that the turning is precise and tight. As well as the caster. Get as much as you can and then even everything out.
Usually we throw weight in the seats to adjust for the driver's weight but it's not always necessary. I would definitely take it in and have it redone though.
I'm taking my car back to the shop in less than 2 hours so I need to educate myself quick!
If you have toe out, that will definitely make your car feel twitchy. You either want a totally even toe setting (0) or toe in. I'd go for even toe.
He also said the caster is maxed out and said it might seem a little twitchy because of my tires (Nitto Invo).
Check out the photo and you can see how all that camber goes away when you go around a corner.
BTW it only takes about $75 in tools and a little patience to properly align an F body yourself. I wouldn't let any shop touch mine.
Accounting for road crowning in a performance car seems bizarre to me...also, not easy to get any negative camber with stock arms on a lowered car, but you want what you can get, that is what keeps the car from following grooves so badly. You won't wear the inside of the tire until you get to -2 or more unless you never turn.
As for toe, the more "in" you run the more it tends to understeer and the "heavier" the turning.
I am a big advocate for the tiniest bit of outward toe and max everything else, but I may be biased by the 1le. I love the way my car handles, factory specs SUCK.
That said, if your bushings are sketchy, do not go toe out or it will be dangerous.
I run very close to OE specs
I am lowered 1 3/4 to 2 '' around, my car handles quite well and gets 42-44 k miles to each set of tires,( 275/40/17 )
just my .02s Johnny
I better way to pick your specs is to align the car for what you are going to use it for. If you are a straight line guy you don't need all that negative camber. It will just wear the insides of your tires especially if you are running different sizes and can't rotate them. If you are a cone carver then the more the better but I would run the same size tires so can rotate them.
For caster I have found +4.5 to be a good setting for both straight line and road racing. Even though some cars will give you more I have seen no benefit to go beyond that.
[QUOTE=therabidweasel;16392611]Accounting for road crowning in a performance car seems bizarre to me...QUOTE]
Couldn't agree more.
If your bushings are sketchy lowing the car will doom them for sure. Bad control arm bushings, especially the lower rear ones, will kill your tires pretty quick. Parts are pretty cheap so if in doubt change them.
https://ls1tech.com/forums/suspensio...alignment.html
