Konis SUCK! High performance, but junk Quality
Location: Fairfax County, VA (You know you're here when you see the bad roads)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
You stated in your first post that Konica are made with substandard low quality components. I believe that is far from the truth. I have Koni SA and from what I have experienced and researched, they are made of very high quality components. I know I have seen bilsteins do this as well on several vehicles I've worked on. If anything, you should only complain about the finish/paint. I do believe that most people will install suspension items and never clean them after install. It seems most don't realize that you need to clean the underside of your car by hand just like the the paint job on the body if you want the paint stay nice.
Not sure if youre joking or serious....but seriously, I actually DID buy another set, though theyre cheaper now. This was of course before I took the old ones off and saw how bad they were. Hopefully the new ones fare better.....but I wont hold me breath.
FWIW my Decarbons on my 98 Were much worse than that. Rusted all the way up the side of the one shock, the mounting ears weren't orange anymore, and they were downright nasty on top (but again, the upper part being shot is a flaw of the suspension design not the shock).
The factory Bilsteins on my Trailblazer were pretty crusty also when I replaced them.
I would say quite often by the condition of those shocks. The OP claims only the shock is rusted but look at the pics again, the spring cup has lots of rust on it also. I promise this car wasnt just driven in the rain, it has been driven on salty snowy roads. Maybe not that often but it doesnt take much once the salt starts working on things. A pic of the undercarriage would be more proof of this.
Then they will just corrode.
This is common with most shock manufacturers. If they installed the bushing after they painted them dont you think that might scratch the new paint up pressing the bushings in?
I confirmed my left front shock kinda looks like @ss around where it mounts to the lower control arm. A little rusty around the perch but not too bad.
I've driven my car in the worst of conditions though, so my situation doesn't really prove much. In fact I thought it would look a lot worse considering I've driven in my parents driveway a million times which is like all puddles and dirt.
#32
When I installed my front koni's, I packed the whole top nut area with grease. Overkill? Probably, but it helps me sleep at night. I'm gonna have to take one off since the shock is leaking so we'll see how it holds up...though my car is lucky if it sees rain.
#34
LS1TECH Sponsor
Last time I checked, metal and water (and salt) don't mix particularly well). Oh, could they make the tops from stainless steel? Sure, which would cost more. Also you could have used a bunch of Anti-seize compound too. I've had shocks that were 9 years old that I sold to a friend (Koni's) that were better those look.
I'm glad you happy my springs held up better in terms of paint. But in all seriousness the only "rust" that's an issue is at the top which frankly would not been have a been issue with anti-seize. Water gets up there and sits. It's not Koni's fault that GM made the shocks they way they did and closed the tops of the towers (which is why the Koni's don't use a **** which would have been really nice).
I understand you might be annoyed, but understand that when it snows your way they use this brine that has a ton of salt in it to keep the lemmings from dying. By best friend lives just north of DC and it amazes me how much his stuff gets torn up when it hardly snows. He just had to replace every hard brake line in his Suburban because they were all ready to fail (GM parts, the originals in an 2004) due to rust. FWIW.
__________________
#35
1) I first learned the beauty of Anti-Sieze about 20 years ago, and I use it religiously on everything....my koni shock tops included. My entire garage and hallway over to the sink is covered with little silvery finger prints.
You'll just have to take my word on the fact that they were installed well coated.
2) Forgive the hyperbole, but maybe if they made the shocks out of the same stuff as your springs, they might have lasted longer?
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
But seriously...do you have a new set of koni shocks in your shop right now? Open the box up and look at how the powdercoating around the spring perch is hastily applied so that if you move the spring perch you will flake off the powdercoat. Look at how the coating is OVER the rubber bushing as well so that the second the bushing flexes in the car it will flake there as well. It doesnt have to be made from exotic materials....some simple attention to detail and pride in work would go a long way here.
3) I dont expect my konis to survive indefinitley all of the crap VA roads, and harsh winter grime we get out here....but those shocks were the FASTEST corroding part on my car! I mean why didnt the spring cups on the shock rust? Why didnt the control arm rust? Why dont your springs rust? None of it is stainless.
I hear what youre saying...just label me as "that crazy guy who thinks his $1000 worth of shocks should last at least 1/3 as long as every other component in the car"
But I still appreciate your comment.
#36
LS1TECH Sponsor
For all the frustration, I still think it's a stretch to call Koni's *junk*. Maybe I'm nuts. And frankly yours look a lot more beat than sets I've seen go through more than one PA winter. I can't say why. What do the rears look like?
As for the Anti-seize, I use it up top, then glop more on when I'm done. I've never had an F-body nut stick up there after, be it on a Bilstein, Koni or even AGX's.
I don't think you are crazy, I don't. I guess I'm just thinking about how the shocks work more than what they look like.
__________________
#37
My decarbons were much much worse than your koni's and the car is a texas car that otherwise is completely corrosion/rust free. I had to use a cutting wheel to cut the nut off the top of the decarbons to get my upper mount off. A $5 bottle of anti-seize and nothing that goes on my car has a chance to rust like that.
I'd be more likely to believe that your koni's just happened to have water sit up there more than the previous shocks. Once water gets up there it literally sits until it evaporates, and depending on how and where you drive your car, that could be a while.
#38
I totaly see your point. So what do you want me/us to learn from this? Not to buy Koni's? If you live in a region where winters are harsh you should better maintain your investment? Better installation techniques to avoid future problems? While this thread does expose some concerns and people have made positve and negative comments I feel once a suspension is installed we may or may not maintain them properly/regularly for the condition(s) we place them. Can we blame a manufacturer for build quality or poor powder coating techniques, maybe but most of the time it's a shared responsibility and Koni wouldn't have the reputation it has if it's build quality was poor. This is an unfortunate circumstance and hope this doesn't keep people from purchasing them but sheds light that when maintaining/washing your car that some attention should be made to the suspension components.
