Konis SUCK! High performance, but junk Quality
#43
Location: Fairfax County, VA (You know you're here when you see the bad roads)
One more thought.....Do any of you guys think it would be adviseable to drill a small hole through the upper rubber mount thing to let water drain out???
#44
I've thought about stripping the shock bodies and repainting in POR15, and then top coating in POR hardnose dark yellow, and my car never sees rain or snow. Maybe this is too much work for most, but if you're car does see regular duty maybe that's thing to do. Along with greasing the nut at the upper mount.
#45
Agreed on the POR15 thing. Definitely given it some thought. Obviously, the top nut has nothing to do with Koni; that happened with my DeCarbons that saw daily duty in NJ for the first 10 years of their lives.
The main difference I noticed, as far as rusting, was from the shaft downward. The 10-year-old DeCarbons still look better than my front Koni yellows do after 2-3 years of life, and next to no winter driving. As long as they're still performing, I have no intention to get rid of them--I just wish they didn't look like they were eligible for Social Security.
#46
In terms of performance the koni shocks are terrific. however, based soley on durability I want to note the my Koni shocks are the single most rapidly corroding and deteriorating item on my car. Heck....the Goodyear eagle DS G3 tires I bought when those shocks were installed still have about half the tread left.
#47
LS1TECH Sponsor
Have you called Koni?
__________________
#48
I called them once and they offered to rebuild them for about %80 of the cost to buy new + shipping and a 30+ day wait. That was before I tried to disassemble everything. I had to destroy the shocks to get the springs off. At which point I pretty much gave up on koni. $1000+ is too much to spend on a second chance.
But Like I said at the start, Im not looking for a free pair of shocks, a hookup or even sympathy. However, I would be totally satisfied if I got an email from koni stating that the've heard the complains and are building a more corrosion resistant setup as a result.
I only made this post to share my experiences with the others on the thread. I am not asking for any resolution or anything from anybody. Other users can chime in with their experiences as well. The reader will have to add it all up and make their own choice. I appreciate everyones comments, and all viewpoints both good and bad should hold equal weight.
All, take what you will from this thread.
#49
I would say quite often by the condition of those shocks. The OP claims only the shock is rusted but look at the pics again, the spring cup has lots of rust on it also. I promise this car wasnt just driven in the rain, it has been driven on salty snowy roads. Maybe not that often but it doesnt take much once the salt starts working on things. A pic of the undercarriage would be more proof of this.
Then they will just corrode.
This is common with most shock manufacturers. If they installed the bushing after they painted them dont you think that might scratch the new paint up pressing the bushings in?
#51
Oil spray
Did you oil spray at least the rust prone areas of the new set? I get my van sprayed every year and it definitely helps. Just an idea…
#52
I've been thinking about this, wondering whether it would weaken the structure of the upper shock mount in some way, or whether the water would be able to drain anyway.
Thoughts?
#59
lol....took the words right out of my mouth.
i love how 3 people in a row agree that rust is not corrosion?!
anyway....Perhaps its hard to see in the pics, but if those konis are like mine, the metal underneath was also starting to lift away in layers
