Pics of BMR spring spacers installed?
Old 06-08-2012, 07:12 AM
oldmano2z's Avatar
do the spacers affect the caster,camber,toe in of the vehicle?? the oldman....
Old 06-08-2012, 09:49 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Anytime you change the ride height it is going to affect the alignment atleast a little bit. Changing up the ride height a 1/2" or less really shouldn't affect the alignment too much but if you are worried the least bit you could have the alignment checked after the spacers are installed.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 06-10-2012, 06:01 PM
camarodude87's Avatar
Yeah well im trying to install these as we speak and I removed both bolts holdin the shock to the A Arm and the A arm didnt just drop, I tryed to pry up the shock, buts it really pressing against the a arm and now the shock shifted, What else do I have to removed other than the two bolts. thanks
Old 06-10-2012, 06:06 PM
kyoytey1693's Avatar
Try unbolting the sway bar.
Old 06-10-2012, 06:11 PM
Alright ill try that, will I be fucked if i do. I mean will I need to compress my shock. if so I dont have a compresser
Old 06-10-2012, 06:25 PM
ramairetransam's Avatar
Might have to take the swaybar endlInk off to get it to pivot down
Old 06-10-2012, 06:41 PM
Yeah I removed the sway bar , but its still not eneough to even get one spacer in there. thats what long L kinda shaped peice that goes from the rotor to the top of the spring? theres a cotter pin holding the castle nut on. If I remove that will I screw myself on my spring? IE compressing it
Old 06-10-2012, 09:22 PM
No, you wont screw yourself, but it doesnt just "unbolt". It will require some persuasion. I like to whack it once with a 20lb sledge. Others use fork or hammer guns. It's not difficult to undo and reassemble as long as you have tools, time, place, and know how.
Old 06-11-2012, 10:10 AM
BMR Sales2's Avatar
You are talking about where the upper control arm and spindle bolt together. If you remove that cotter pin out of the castle nut and remove the nut and hit the spindle with a hammer a few times you can get that to break free and you will have more than enough clearance to get that spacer in between the shock and the a-arm. Once you get the spacer mounted in there you can bolt everything back up and make sure you use a cotter pin on that castle nut and you will be good to go. Doing this will have no affect on the spring at all.
__________________
Glenn ***
Sales Tech
813.986.9302
Quick Reply: Pics of BMR spring spacers installed?
