Any reason to NOT just get new factory motor mounts......
#61
I sat in the machine shop one day of a very respected Super Stock racer who has won multiple national races. He told me he believed that solid mounts could lead to cylinder distortion...especially with filled blocks. For this reason, he liked to use a rubber mount and a torque strap if you can't use motor plates.
And now for the clincher...for all you old farts out there...go back to around 1968. IIRC...and I think I do...Chevrolet had an issue with their motor mounts in the Camaro. Their fix? EXACTLY what was shown here. A safety cable until new mounts could be designed.
#62
Well now, think about this for a moment. While very unconventional, I could see some merit with this. If you are concerned about vibrations caused by stiffer mounts, using a factory mount on the right side may help. Remember...that mount is under very little stress compared to the left side. That would be an interesting combination. I wonder if there is a noticeable difference and if there were any issues induced by this.
#64
With my iron block I don't have to worry about cylinder distortion as "OldCobraGuy" mentioned. And its cool he mentioned this because I read something about that once.....IIRC the article I read said there's no worries with iron blocks, just aluminum blocks.
