Strange Engineering Front Shock S5269 Install Questions
Started to assemble my Strange Engineering SA front shocks S5269.
They are the street version and bolt to the factory upper strut mount.
Questions:
Is a 2" daimeter thick fender washer required between the upper strut body and the shock shaft? It appears that the use of a fender washer would distribute the load better.
Are the factory bump stops required for use in this setup?
Thanks,
Mike
Questions:
Thanks,
Mike
