Before And After Lowering Springs
#62
The coil cutting dropped it. .625 inches. Never measured when done just hose mod at first. Just know bottom of rear fender bout one inch higher than front.
#63
Where the coil winding stops at top i cut straight across spring from that. The cut off piece should make a c lol. Then slid hose back on spring and back in car
#65
Lol ya I was guna ask if half a coil would be a C... Thought that would sound silly. Guess not.. Ok I might give this a try. I would cut the bumpstop tho. We use those more than we think.
#69
Speaking of which...what kind of issues can I expect with a set of BMR springs on the rear and 315's on 17 x 11 wheels? I get no rubbing at all now...and I've already removed the bump stops. (have to build something there some day)
#70
Whats the purpose of the heater hose? to give it some padding. I ve seen it used with eibach pro kit. but usually with the pro kit... it seems the *** end of the car always sits lower already.
