SLP Bilsteins and BMR Springs
#43
Just get your fender rolled. Only reason I havent is because this car is somewhat rare. I really don't want to do anything that cannot be reversed. Only thing I did do was clearance the inner fender a little in the rear where the 315 will rub all the time if you don't give her a little BFH work. I actually just run 17x9 stock SS wheels on the street and 99% of the time. IMO, difference between 275 and 315 is pretty negligible. If you add 5-10 pounds of wheel and tire, you're not really gaining anything over an aluminum wheel with a 275 tire. Unsprung rotating weight KILLS a car.
#44
#45
I went from stock Decarbons stock springs to Bilsteins and BMR springs, definitely LOVE the look, that's mainly what I did it for. In terms of performance, it's not a huge improvement but definitely a little flatter in corners, ride quality is decent. They do the job for sure. The Decarbons were more comfortable, but obviously with stock height springs they're going to be. With the bilsten/bmr combo the marginal loss in ride comfort is well worth the improved handling and 1000x better looks.
Oh and BTW, the BMR springs take a good amount of time to settle in to proper ride height. My car sat a bit high for a while, I was starting to get dissapointed thinking they didn't drop it nearly as low as I hoped, but after a few weeks it's sitting right about where I want it at.
#46
#47
Just thought if add my 2cents.
After going from 'good' factory replacements to Bmr springs and slp bilsteins the ride is night a day.
It's rougher then before but I can actually feel the road now! Much more planted on the ground. Very good quality from what I could tell.
I also did control arms with relo brackets and a tunnel mounted TA at the same time. Car used to feel unstable when letting off the throttle at 100mph now it's straight as an arrow!
#48
I have the BMR/Bilsteins setup on mine due to this thread, and I love the ride. Performance and stance compared to the 26k mile stock setup I had before is night and day. The car not only looks more agressive but it handles much better and as someone above said you can feel the road.
I did the front BMR springs and the heater hose mod in the rear with SLP/Bilsteins on all four corners.
I actually ordered a second set of BMR springs this week so I can switch out the Eibach Sportlines on the stagecoach riding 97'.
#49
LS1Tech Premium Sponsor
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I always lie to get as many pictures as I can for our lowering spring picture database.
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
#51
im getting the itch from this thread! BMR springs, blistien shocks, BMR Front/rear sway, and BMR upper/lower A arms being installed as we speak. already have the BMR LCA/Panhard on the car. cant freakin wait! wed i shall take the beast to get aligned, any alignment specs i should look for?
#52
Hey Kyle, I installed my koni's/bmr's this weekend and they look great. Is it common for the drivers side to be slightly higher than the passengers side? I measured from the ground to the top of the fender and it is higher on the drivers side by about 1/8th inch. Wasn't sure if this was common.
Don't mean to thread hijack.
#53
