Refreshing old suspension
I'm looking to make my suspension ride a bit smoother / tighter, specifically in the rear suspension. A little history on the car, 2001 Camaro SS, installed BMR tubular Panhard and BMR boxed LCA's back in 2002. Not sure if they're poly or rubber. At the same time installed Eibach pro kit. This was at 40K mileage, car is now at 100k. The car also unfortunately sat garaged from 2007 - 2011, which seems to have caused a lot of the issues in the ride quality. The tires are also a few years old (nittos 555R).
Recently I've upgraded to Koni's and Stranos which improved the car drastically in handling, but I still feel like it didn't fix the 'play' in the rear suspension, especially around town on less smooth roads. Almost like a side to side of the rear end, kind of wobbily. I also get a bit of clunking when going over bumps from what sounds like the right rear. All these issues were present prior to the Koni / Strano install, and the new shocks / springs did help quite a bit.
I want to fix the issues, but I want to weigh my options first on what needs to be replaced. My options that I am thinking of trying are:
1. Tires
2. LCA /PHB bushings
3. Sway bar replacement
4. Subframe Connectors
4. Other
What do you all think would be the best bang for my buck based on the above scenario? If you were to replace bushings, poly or rubber?
Thanks in advance.
A few other items I forgot to mention above. Rear tires are 315's. Settings on Konis were Front - 4 sweeps from full soft, Rear - half turn from full soft.
Today I began troubleshooting and did the following which helped:
Slight -Dropped tire pressure from 38/38 to 32/30 front/rear
Moderate - Removed subwoofers (two 10's and amp) from rear of car
Significant - Decreased rear setting on Koni's from half turn from full soft to full soft (0).
I'm hoping that replacing the worn LCA and PHR bushings, an alignment and new tires will the issue and return the ride quality as much as possible for an Fbody.
So would you say ditching the poly bushings improved handling as well?
I'm in the same boat as OP. My car is an '02 TA with 116,XXX miles and the suspension is totally stock. My first "phase" in revamping my suspension is buying lowering springs, shocks, and PHB/watts link (What is the difference in these?)
My main question is about the poly/rubber ends you guys are talking about. What ends would be recommended to someone like me who is refreshening their suspension. My car is a DD and will honestly never see a track, and its a long shot if I ever go to a 1/4 mile track.
Thanks for your input guys!
As the axle moves up or down, the angle of the joint relative to the axle changes but the mounting point is perpendicular to the poly link and does not give. So it is the job of the poly portion to deform and provide give. The only problem is that it can only give so much, far less than a roto joint would allow (28 degrees for the roto joint) The result is at bind point, the suspension locks and this is felt as "snap" oversteer as I recall. Either way the description is like someone threw a boat anchor out the side making you turn harder unexpectedly and pushing for the rear to break loose and cause a spin.
The thing is for comfort purposes, as you go over road imperfections, bumps etc, your wheels go up and down, and you will STILL hit the bind point of the poly resulting in a harsher ride out back. Harshness is relative to the person, but it would be like hitting a pot hole the size of a manhole with the back tire when it was a small fist sized hole with the front.
If you can get the rubber ends (BMR has on hand!) Go for it, poly when done right isn't as bad as it seems if used in spots where bind is not an issue. Ie panhard rod will see little to no deflection as when I took mine off after 6 years, the ends looked lubricated and untouched compared to the poly on the lca's which were scored, marked and imprinted in how it binded.
