Was Firestone BSing me?
BUT... after the guy saw that I wasn't happy... he told me he wasn't going to charge me anything. So that was nice of him
So is the "special tool" bullcrap? Or is there something that I've never heard of before...
Here is what the paper said that he gave me...
Front Left:
Camber before:-0.3 After:Same
Caster before: 5.0 After: Same
Toe before:-0.03 After: 0.00
Front Right:
Camber before:-.7 After: Same
Caster before:6.3 After: Same
Toe before:-.06 After -0.02
Also the rear toe is weird...
Left: 0.12 Right -0.06
If not, then there is no reason that they couldn't take care of you.
If so, some places will not touch an aftermarket setup, for whatever reason.
I don't see any reason for him NOT to do my car...and since he didn't make me pay... maybe he just didn't know???
There is a ""special tool" made, but "who" needs it, I retaired in '07 after 30 years aligning autos( front/rear/sideways I never say a need for this tool, I only used screw driver/pry bar ( tried the tool once and the pry bar works faster for me)
"Here is what the paper said that he gave me..."
Front Left:
Front Right:
OK.. camber is ok -----I like a little postive
caster has a little muck differance side to side...I like only about 0.50 more on right not the 1.3 you have --this may cause pull to lefr which would put you into a head on kiss
I like a lttle postive toe ( which you had before the tech begain )
now you are a little neg on toe, not a bigge, may allow a little road wander and a small amount of wear on inside of tires
rear toe a'nt bad .... Rear Thrust Line be a little postive..
I pull very stright with about the same
BUT auto are about like the ladies, most have their likes/dislikes
Just my 0.02s Johnny
or
Maybe they knew and tried to squeez by well knowing they could not do the job. In that case yes they do suck.
What if you went to get a cam installed at a place that does cam installs... and they take off your valve covers and say "sorry can't do it... we don't have a spring compressor" Same concept...
