C5 calipers a direct bolt on for f-bodies?
I know you can't use the C5 rotors without using the relocation brackets. However I like the look of the red Z06 Calipers and was told that those would bolt right on and I would be able to use them with my stock f-body rotors. This true?
Just out of curiousity, if the only reason you waant the C5 calipers is because you "like the look" why don't you save yourself a ton of money and just buy a can of VHT, clearcoat, and a set of caliper stickers from Afterthoughts? If you want increased braking ability than thats another story but I think to fully utilize the calipers, C5 rotors would be needed also.
Here's a pic of my stock rotors I painted: http://home.cogeco.ca/~brettstransam/101-0179_IMG.JPG
Originally Posted by mitchntx
Never heard of one breaking. As frugal as GM is, why do you think the bolts are different? The ears on the calipers are different between the F-Body and C5 ...
