ATTN: UMI Front Suspension Alignment Problems
A few months ago I installed a UMI road race K-Member(#2321), and adjustable upper (#2310) and lower A-Arms(#2305) in my 2002 Camaro SS. I got everything as aligned as I could and turned it over to the professionals. Since then, I have been battling alignment problems. I have been to three different places attempting to get an alignment, one being a chassis shop here in Maryland. So far, we have been able to get everything correct except the caster. Does anyone have any experience or recommendations?
Unfortunately, I got too excited and sold all of the stock pieces so there is no going back.
Thanks!
Matthew
Thanks!
Matthew
I would get in contact with UMI. I have all the same stuff minus the k-member and never had any issue. My sig has the list if that matters. My only guess could possibly be that the k isn't in correctly or moving around, but like I said that's my best guess. One more possible thing is that the jam nuts aren't set on the arms. A descent shop should check that though.
What specs are you shooting for? Can you provide a current alignment sheet?
How many threads showing on your uppers? Lowers? Factory setting is 8 threads showing or 7/8" inside the arm.
If the k-member went in properly on the alignment pins and all six bolts went in properly you should be good to go. The adjustment slots are factory location plus some additional length for "extra" alignment. Each k-member goes through a QC check before it leaves to make sure the slot location is correct.
Most alignment problems can be fixed with a bit of consultation and sometimes a call when the car is on the rack.
later
ramey
I am an idiot! It was an error on my end. I had one of the uppers installed incorrectly.
Thank you guys for the great customer support. I will continue to speak positively of your business, and recommend you to potential customers.
And while I'm at it, I'll throw out a +1 for Obsession Motorsports. Was on the phone with them a few times. Great group of guys.
