T/A wont align to specs PA tubular K member
Yes correct. And update after conversations with PA racing their two recommenactions are to either enlarge the slots or get aftermarket a arms. On their website it clearly states that their k member will worik with stock a arms and align to specs but guess not.... I asked if enlarging the slots would weaken the unit and they said it wouldn't. I don't know how truthful this is.
After buying a new k member I would not want to grind the tabs....and I didn't. I ended up going with a set of their arms as well. PA knocked some off the price enough (and theirs are the cheapest already) that I was happy with the deal on them.
So this is a known condition with the PA k-member (not enough camber adjustment with stock a-arms)...?
They described it as hit or miss with my situation. He said some have issues, others do not. My issue was my arm (bushing area) hit the k member before it could be adjusted all the way in, leaving me minimal adjustment inward. The aftermarket arms have small bushings so there is plenty of adjustment area.
When I spoke with them they made it seem as if I was the first one with this problem ever. Actually he did state that to me that I was the first person to come back with alignment issues but clearly I am not.
#32
Well, our two issues are clearly different. Your stock arms will adjust all the way in.....Mine wouldn't. He said the main hoop bend could change this, even a slight variation could cause the problem I was describing. Yours is a problem of a different nature....but is still not guaranteed to be the k members fault. Getting back in a jig would be the only way to verify.... unfortunately.
#34
It held me up at the time and I was pretty frustrated. I doubt I took any pics. I will look back in my phone and see though and if I run across them I will post them up.
#35
Bringing this thread back from the dead. Been busy with school and work but anywho I spoke to PA racing and they said that I need aftermarket arms to run this K member (even though it says it works with stock arms) or I can just grind the tabs and enlarge the adjustment slots for the alignment. What would be the best tool to open up these slots? I was thinking a drill bit and a high powered drill but I'm sure there are better ways out there.
