Would a tubular LCA with Rubber Bushings allow for some articulation?
If your looking for a poly control arm that allows great articulation I would recommend our swivel joint arm.
http://www.foundersperformance.com/p...mbination.html
![](http://www.foundersperformance.com/product_images/a/885/Swivel_Joint_Apart__89752_zoom.jpg)
I just put them on for the second time and am not liking the oversteer problem on highway turns. Do you have a "trade in" program so that I can get those?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I see what "hiltsy" did, and it's somewhat similar to a pair of LCAs I made up shortly before I retired (and lost my access to a machine shop). Simply, you purchase some thick walled steel tubing and lathe cut it to accept the Moog bushing. After you weld everything up, you press in the bushing like you would do to the OE LCA. In "hiltsy"s case, he went a step further than I did, and made them adjustable.(excellent idea) I simply made mine to "OE length".
