Suspension overkill?? Need advise!
Old 09-11-2012 | 10:29 PM
z28bryan's Avatar
Originally Posted by redlineracing
LCA's made a drastic difference on my car..
Difference in what?
Old 09-12-2012 | 12:03 PM
YellowToy/A's Avatar
I would go for quality for quantity. Koni shocks with Strano lower springs first on the list. LCA with poly/roto joint next. Then Strano sway bar kit, 35mm hollow in front and what ever it comes with in back. Watts linkage in back later. If you get big power get subframe connectors.
Old 09-12-2012 | 01:35 PM
redlineracing's Avatar
The root joint ends on my LCA's feel much firmer and articulate much better than the stock junk rubber. The car used to spin well into second as well as wheelhop. After the LCA's I spin half no distance with zero hop. Well worth the money as wheel hop is what kills 10 bolt a4 cars.
The roto joint ends on my LCA's feel much firmer and articulate much better than the stock junk rubber. The car used to spin well into second as well as wheelhop. After the LCA's I spin half no distance with zero hop. Well worth the money as wheel hop is what kills 10 bolt a4 cars
Quick Reply: Suspension overkill?? Need advise!
