Having UMI LCA relocation issue...
Old Sep 13, 2012 | 07:26 PM
pillarpod's Avatar
Default Having UMI LCA relocation issue...
Went to put my UMI relocation brackets and new control arms. Drivers side i had no problems what so ever. But worked on the passenger side, it fought me the whole way. heres some pics
This is the driver side
This is the passnger side, and somethings twisted. Don't know if it the brakcet or on the axel
I got all the bolts in. Is this okay to leave like or no?
Old Sep 13, 2012 | 07:34 PM
Mystery Bird's Avatar
Did you try tightening it up? It almost looks like it will draw itself up when tightened with the gap on the left side.
Old Sep 13, 2012 | 07:39 PM
pillarpod's Avatar
i have not. Didn't want to get it all back together then tear it all back down
Old Sep 13, 2012 | 07:46 PM
TwoFast4Lv's Avatar
Looks like the whole axle tube is bent. Might be time for a housing!
Old Sep 13, 2012 | 09:42 PM
FAD2BLK93's Avatar
Tighten it down and draw it together. Looks like it should straighten itself out.
Old Sep 13, 2012 | 09:50 PM
camarokid91's Avatar
Those are a pain to put in, your passenger side doesn't look right tho. As everyone else stated tighten it down.
Old Sep 13, 2012 | 09:59 PM
CamaroRacing12's Avatar
zap that motha with the impact!
Old Sep 14, 2012 | 04:59 AM
RamAir95TA's Avatar
Shoulda gotten the weld-ins!
Old Sep 14, 2012 | 05:44 AM
01ssreda4's Avatar
How is a bent axle tube going to cause a bracket to sit on another bracket crooked? Please explain that one to me
Old Sep 14, 2012 | 08:34 AM
UMI Performance's Avatar
I assume from the picture the plate we weld on the back is just sawed crooked or placed on crooked. That plate is a piece of 3/16" x 4" sawed to length and welded on the back as a support plate, nothing special. It could be sawed crooked or the welder placed it on crooked. It doesn't effect the hole locations in anyway, they are bolted to the fixture using bolts in all holes and the plate is placed on last. If all the bolts are in you are good to go. Again that back plate won't effect hole location. I will show this to the welders in the shop and investigate the fixture, it looks like a cross eyed welder to me
Old Sep 14, 2012 | 08:41 AM
sleeperLT1Z28's Avatar
Looks to me like the upper left mounting hole is drilled too far toward the top of the bracket. Seems like the whole piece is riding low on the left side. Maybe you could measure the distance between the holes on both sides. If there is more distance on the drivers side, then you found the problem.
Old Sep 15, 2012 | 09:26 PM
bill12690's Avatar
i agree.
FWIW, i didn't have this problem with my relos. also from UMI
Old Sep 15, 2012 | 09:54 PM
01ssreda4's Avatar
I was thinking a drilled hole issue also.
Old Sep 16, 2012 | 07:19 AM
leadfoot4's Avatar
Bingo!!!
Old Sep 20, 2012 | 07:52 AM
Undertow74's Avatar
I would suggest not jacking the rear of the car up by the swaybar and mounting bracket
Old Feb 1, 2014 | 05:35 PM
pillarpod's Avatar
I'm bringing this back from the dead. My rear control arms have been on a little over a year and with about lil over 2500 miles on them. Is this okay that they are crooked?
Driver Side
Passenger Side
Old Feb 1, 2014 | 06:01 PM
01ssreda4's Avatar
What kind of bushing is that? If its rubber or poly it looks like they need to be replaced.
Old Feb 1, 2014 | 06:23 PM
pillarpod's Avatar
using on car adjustable poly/roto joint. It was like this when I put them on from day one
Old Feb 1, 2014 | 06:28 PM
metalmilitia606's Avatar
Mine were like that and clunked and rattled like no other. I love UMI and have all my stuff from them, but I dislike the roto joints. I swapped all of them back to poly and put back on the stock LCA's. They are supposed to move like that though.
Old Feb 1, 2014 | 11:57 PM
99Bluz28's Avatar
They're only suppose to move like that when you have Roto-joints or Rod-ends on both ends of the LCAs.
With you have the fixed position poly bushings on the front of your LCAs then the Roto-joints at the rear should be straight, NOT angled. I'd check the jam nuts for the length adjustment I bet they're loose on both LCAs.
