LCA install advice
Old 04-08-2004, 07:06 AM
99gator's Avatar
Default LCA install advice
Ordered BMR LCAs and they appear to be a simple install. But, anyone got a link to step-by-step instructions to ease my mind a little? Thanks for the help.
Old 04-08-2004, 08:18 AM
95_Firehawk_Dude's Avatar
Install University has an install document for BMR LCA's that you can check out.
Old 04-11-2004, 07:50 PM
Hawkeye2's Avatar
they come with instructions that are easy too follow. they only "trick" if you will
is to leave the jack under the rear end. If the holes don't line up at first, then
you can raise or lower the car a tad - it will help line everything up. just remember
to "load" the suspension before torquing everything down.
Old 04-11-2004, 08:24 PM
z28hokie's Avatar
And only remove/install 1 at a time
Old 04-12-2004, 12:46 PM
Turo's Avatar
i did some spohn lca's and bmr brackets thsi past weekend. pretty easy install, i just followed the instructions on www.installuniversity.com . like z28hokie said, do one side at a time.
