BMR/Bilsteins DD worthy?
I daily drove on SLP Bilsteins and Hotchkis springs for about 4 years. The Bilstiens worked better than stock and Tokicos. Running soft tires like the Starspec, NT05, or RT615 made the set up shine for handling.
The key is to keep a softer rear rate. It ran some stiffer and shorter springs and the car road like a flat bed truck with the rear skipping on imperfections around turns. In the end, an f-body will never ride smooth.
#36
Overall for the money. It would be tough to beat a Bilstein shock with a cut spring. The cut spring would add a little stiffness to the spring and the shock is good enough to do it's thing.
#38
To add here I'm running Bilsteins w/ a pro-kit. Ride isn't bad nor great . I steer clear of bumps and drive different routes to get away from bumpy roads. I've been thinking to going with a cut ws6/ss spring. Looking for better ride and better weight transfer at the track
#39
