k member question
Old Jan 20, 2013 | 05:16 PM
bungy74's Avatar
Default k member question
will a k member from an lt1 camaro bolt right up to a ls1 camaro ?
Old Jan 20, 2013 | 05:20 PM
bungy74's Avatar
or does anyone know if they are the same ?
Old Jan 20, 2013 | 06:54 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
The LT1 k-member will 100% bolt right up to the chassis of the vehicle but the motor mounts will be different so if you are using a LS motor it will not work for you.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Jan 20, 2013 | 07:12 PM
bungy74's Avatar
i have 2000 z28 with no motor, considering placing old small block in it to mess around with at the track. I wonder if someone makes mounts to put the old small block in the car ?
Old Jan 20, 2013 | 11:22 PM
01ssreda4's Avatar
Body molds did not change. All parts body mounted parts interchange. But you need the matching k member engine combo for the motor mounts to work.
Old Jan 21, 2013 | 04:07 PM
studderin's Avatar
BMR dose
KM005 for a stock steering rack
KM005-1 for a manual pinto rack
Old Jan 21, 2013 | 05:16 PM
ss performance's Avatar
Check with whoever made your K-member. Most make conversion kits or can direct you to someone that does.
Old Jan 21, 2013 | 06:43 PM
UMI Sales's Avatar
You can install a SBC with this:
http://www.umiperformance.com/catalo...roducts_id=588
One minor consideration (or major depending on your intended use for the car) is how close the air cleaner will fit vs the windshield wiper/cowl area.
-- Ramey
Old Jan 21, 2013 | 08:12 PM
bungy74's Avatar
i didn't want to buy a different kmember, i just thought maybe someone made mounts to put the sbc in on the stock kmember that the ls1 used to sit on
Old Jan 22, 2013 | 09:48 AM
Yes they are made. I just saw some on the TV show MuscleCar this past weekend. If you go to thier web site you can watch the show.
Hope it helps.
