Car to sit for 1 year or longer question
I searched and couldn't seem to find an answer to my question. I'm currently working on my 2002 camaro z28. Redoing everything from suspension, rear end, wheels, tranny, and engine. I just got finished with the front end suspension, bmr k member, upper and lower a arms, strange shocks and hypercoils. Next I plan on doing my rear (mwc fab 9) then onto the engine and tranny. My question is, I don't plan on being done till next summer or even longer, so should I put my car on jack stands for that amount of time where the suspension isn't loaded? Or is it ok just to leave it on the ground? Or any other advice or tips? It will always be garaged too. Thanks
Jordan
Jordan
Location: Land of the Mormon's although I'm not one of them
It's fine to leave it on the ground; but seeing the whole front end is new, and I'm assuming you're replacing the rear springs/suspension as well, jackstands will be fine too. The issue comes in when leaving it a long time on stock/old springs, they can sometimes cause issues, but with you having all new stuff, it shouldn't be an issue.
I was told by a friend that his buddy's QA1's started leaking after the car spent time on stands (suspension fully unloaded) for an extended period of time (not sure how long). I have QA1's SA's so when I put my car up for three years I place the stands under the rear axle and the front k-member. I used some blocks of wood to place under the A-arms to prevent them from fully unloading.
Ok thanks guys. It's on some roll around rims and tires anyways so ill just leave it on the ground for now. And the whole rear suspension will be redone as well so no worries about that. Thanks
Jordan
Jordan
