aluminum sway bar mounts?
I'm going to say up front that I know this is WAY out and NOT streetable. There now its been said so I don't want to hear it.
I'm looking for a set of aluminum sway bar mounts to replace the poly mounts. Does anyone know where I would find a set or is this something I'm going to have to make?
I've seen custom made aluminum blocks with a nylon liner that were used as frame mounts on the occasional racing application. But I'm not sure if anyone makes them for sale. I'm guessing that you are wanting to change the frame mounts. If you are wanting to upgrade the end links, look up ground control, they sell a kit to use Heim joints for end links, virtually 0 deflection.
