Are all subframes the same??
Old Apr 19, 2004 | 09:05 AM
KINDA_FAST's Avatar
Default Are all subframes the same??
The only diference i see is that some are bolt on and the others weld in. Whice ones are the way to go?
Old Apr 19, 2004 | 02:45 PM
Funker's Avatar
I've been wondering about this as well. Also, is there much variation in quality between different manufacturers of SFC's?
Old Apr 19, 2004 | 03:23 PM
DARK AGE 53's Avatar
SLP or Don Goezt bolt-on SFC's will work just fine for you. JMO
Al
Old Apr 19, 2004 | 04:12 PM
dc33cool's Avatar
My SLPs bolted right up out of the box, but some minor modification might be neccesary depending on if all the holes line up correctly. With weld-ons you can jack the car up ont the SFC which is pretty cool. My vote goes to Bolt-ons tho.
Good luck with whatever you get.
Old Apr 19, 2004 | 04:15 PM
Funker's Avatar
Why do you favor bolt-ons?
Old Apr 19, 2004 | 09:20 PM
dc33cool's Avatar
Easier to install, unless you do can do the welding, also I belive the suspension needs to be properly loaded (ie on a lift) not positive of this tho. Bolt-on made made more sense for me.
Old Apr 19, 2004 | 09:27 PM
Mike98WS6's Avatar
My vote would be for the SLP bolt on's.
Old Apr 19, 2004 | 10:00 PM
1BADFNZ's Avatar
yeah the slp bolt ons need to have the suspension loaded when installed. They get my vote as well
Old Apr 20, 2004 | 07:56 AM
white//ss's Avatar
If you are looking for the greatest impact go with Kenny Brown "double diamond" weld in. A welded SFC will not flex as much as a bolt in will. Yes bolt in are easier but what do you want? a stiff chassis or ease of installation?
Old Apr 20, 2004 | 12:36 PM
Funker's Avatar
Another question regarding SFC's - do they have any noticeable impact on ride quality/handling at normal cruising speeds, or are their benefits only noticeable during more aggressive driving?
Old Apr 20, 2004 | 01:12 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I put SLP bolt on subframes on my 02 SS about a month ago. One word: BEEFY. The things are huge, and you can see them hanging from under the car. Luckily, they are black so you don't notice as much. If you get them, you'll know what I'm talking about. Mine didn't bolt right in, so I had to do some grinding. Nothing major, but a PITA nonetheless. Since then, I've had them welded in place just for extra peace of mind.
As far as the ride quality, you'll notice it stiffens everything up. No more dash rattles, and the car feels very stiff. You'll easily notice it when daily driving it, and especially when you are flogging on your car. You can tell the suspension has to do a lot more of the work (which it should) instead of the body flexing all over the place.
Old Apr 20, 2004 | 01:28 PM
Tiznobias's Avatar
Checkit, on LMPerformance.com, the SLP bolt-on SFC's costs $100 more than the weld-on's. So, since when properly installed (i.e. suspension is loaded, etc) weld-in's will provide more rigidity, why not spend 100 bucks LESS and get the weld-in's. If you need to have them installed professionally, then do it. If you end up spending the whole $100 you saved, then you still come out on top with welded in SFC's as opposed to bolt-on's.
Old Apr 20, 2004 | 02:11 PM
John95Z28's Avatar
The only difference between the SLP bolt-ins and weld-on is that the bolt-on version is powdercoated. Lots of people have chosen to get the bolt-on style, and then weld them anyways, because the finish / corrosion resistance is better with powdercoating. Some have said that it's just about impossible to keep a coat of paint on the welded version, because of the sandblasting effect from the roadway.
Old Apr 20, 2004 | 02:27 PM
Tiznobias, The weld-on's may cost less but there also not powder coated either, and unless you do your own welding plan on paying $50 to $150 to have them installed.
Steve, There's usally a little modding needed when installing the bolt-on's, each cars a little different plus body flexing that's happened before the install of SFC's, so it's no surprise to me you had to do a little grinding. I would have not welded them in but then again it's not my car.
Here's a link for anyone thinking of installing SLP bolt-on's SFC's. http://users3.ev1.net/~cnl1/firehawk/subframe/index.htm
Old Apr 20, 2004 | 02:50 PM
Tiznobias's Avatar
DARK, yeah I noticed that powder coating thing....the KG DD's are supposed to be zinc-chromate plated to reduce corrosion...that as good as powder coating? Also, the KG DD's and the SLP's look pretty similar, how do they compare to each other? Strength? Weight? I plan to have them welded in, plus I have T-tops so I want to get stronger SFCs...sigh...i know this debate will rage on forever
Old Apr 20, 2004 | 03:08 PM
Tiznobias's Avatar
sorry, in my previous post im referring to the KB DD's, not KG...
Tiznobias, Get the SLP or Don Goezt bolt-on's, you won't be disappointed. JMO
Old Apr 20, 2004 | 03:41 PM
John95Z28's Avatar
Originally Posted by Tiznobias
Also, the KB DD's and the SLP's look pretty similar, how do they compare to each other? Strength? Weight? I plan to have them welded in, plus I have T-tops so I want to get stronger SFCs...sigh...i know this debate will rage on forever
I was wondering that myself: the SLPs are supposed to weigh 20 pounds each side; can anybody confirm this?
Also, what do the Kenny Brown's weigh? 10 to 15 pounds a piece(?)
Old Apr 20, 2004 | 04:09 PM
MeentSS02's Avatar
Al (Dark Age 53),
I wasn't surprised that I had to do some grinding either...not all cars are the same, and I guess it is all a part of the ball game. As far as the welding went, I got a GREAT price on having them welded in, so I didn't even bat an eyelash...I can't say that I noticed any difference in the stiffness, but then again, I really won't have to check how tight the bolts are from now on. I like them, and it isn't anything a grinder couldn't take care of if need be.
As far as the weight, I never weighed mine, but I wouldn't be surprised if they weighed 20 pounds for each side. These are extremely beefy subframes...I compared them to some DDs, and they were seriously at least twice the size of them material-wise.
Old Apr 21, 2004 | 11:43 AM
shaneSS's Avatar
I have bolt ons but got them welded afterwards anyway. Payed teh extra 100 for the powdercoating I guess. I have to dremel out the subframe alittle to get one of the anchor bolts through though. Either way just get them you will not regret it. Also if your car has some milage when you do the blot ons (like mine did (40k)) then you may have to fight to get the holes lined up doe to body flex that has already happened due to the lack of SFC's.
Peace.
