know these Torque Specs? - front control arms
I did a search and came up with nothing. Looking for the following torque specs ASAP:
1.) Front upper control arm/ball joint to spindle (1 castle nut)
2.) Front Lower control arm to K-member bolts (2 bolts; these adjust suspension settings)
Thanks in advance!
Thanks in advance!
You aren't confusing the lower ball joint to spindle, are you? I torqued mine down to 120 ft-lbs. which was the call out on Moog's instructions. I just did a complete rebuild, including bushings and ball joints.
I got everything together last night. For the lower control arm bolts I torqued both to 81 ft-lbs (will be taken off in 5 miles for my alignment anyway).
As for the lower ball joint, I went with 100+, since that's what Moog called out in the instructions provided when I pressed in the new ball joint. It's got a castle nut on it, like all ball joint studs. I'm not sure why Moogs' torque spec is 20% higher than OEM. However, I won't lose too much sleep over it considering the castle nut and cotter pin are extra security. Getting a torque wrench on the upper was hard due to the tight tolerance in relation to the spindle.
Put in my new strano front sway bar last night too.
Road Atlanta this weekend for my first track day with the new components!
