Strange s60 and fays2 watts link
I have a 00 camaro ss. Just wondering if anyone has run this set up? Wondering if the fays2 watts link hits the dif cover at all? Jay said the link can mount up to 3.25od tubing, so I am ok there, just wodering about the dif cover clearance.
thanks,
david
thanks,
david
A search would have solved this for you, however since I've already done it I will tell you.
Yes it will fit, you need to mention your rear axle tube size when ordering the watts link. Call Sam Strano at strano performance and he will give you the best deal on the link and order it correctly for your rear.
