Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tire Repair and Maintenance
- Camaro and Firebird: Tire Diagnostics Guide
Guide to diagnose trouble and recommended solutions
Outer edge tire wear, why why why
I don't trust tire shops. they've screwed up my ride every time. this is a great thread and I've seen great advice. What I'm curious on is how to set up camber, toe and whatnot for a staggered set where tire rotation is not possible! Hence the factory specs can go out the window like a 401k handbook... so that being said, what would a guy tell a mechanic ( a good one) how to adjust the ride to get even wear?
IMO, I stay away from the chain-store shops. Try and find a local family owned mom & pop shop that been around for a long time, and if you're lucky they'll have a alignment guy that's a perfectionist an will do performance/custom alignments.
A good alignment guy should know what to ask, look for, and do to fix you alignment issues.
My local alignment guy always asks me plenty of questions, has never guaranteed me that he could set my alignment exactly were I want it, only that he'll get it as close as possible, and he usually get it really close. As far as the Toe I just leave it up to him set the Toe where he thinks is best from the info he gets from me.
So we got a few people saying slight toe out and a few others saying slight toe in. I'm not sure if it's just different opinion or confusion between toe in and toe out (when they meant the opposite)
When moving forward, I can understand how the toe will sit even once the car gets moving... but is it starting slightly inward or outward before it becomes even toe under movement?
