Suspension question
Old Jul 25, 2013 | 04:54 PM
Chevyguy2001's Avatar
Default Suspension question
So my SS is a 2000, is it normal to feel every little bump in the road or do i have to get new shocks and stuff?
Old Jul 26, 2013 | 06:10 PM
JD_AMG's Avatar
This is almost too much of a personal taste question with a twist.
First consider that one guy will think something rides very well while another might think its entirely too soft, or too stiff.
Next consider all the different variations from the factory and aftermarket that could change things. Various different shocks and springs were offered for these cars through out the years, then someone could have put an after market set on. Aftermarket LCAs, swaybars, PHB, and bushings can play a huge role in ride quality. Then there are tires and tire pressure (make sure you are not above 30psi). Different tires ride differently depending on sidewall stiffness.
So if you are more specific we can help see if something is causing an issue, or everything is working, just your particular setup is too jarring for you.
Me personally I found the stock (WS6) ride quality to be a bit on the jarring side, but also too loose at the same time. This was a shock issue (stock decarbons), too much compression dampening and not enough rebound for me.
Old Jul 27, 2013 | 08:23 AM
UMI Performance's Avatar
Hello,
How many miles are on the car? Stock shocks and springs?
Old Jul 27, 2013 | 11:49 AM
ZForce1's Avatar
If you're not happy with the ride, and it has stock shocks, I would say definitely get new shocks. The factory ones were pretty bad. That alone will made a huge difference, as most here will attest to.
Old Jul 28, 2013 | 08:46 AM
Original shocks, 58,xxx miles
Old Jul 28, 2013 | 01:08 PM
Stock springs too?
Old Jul 28, 2013 | 08:08 PM
Yes, Ryan were you the one with the WS6 at carlisle for the ride alongs?? if so, i was the one in your car when you shut it down because she was getting hot, then you got out and it was pissin out coolant. It was a great ride!
Old Jul 31, 2013 | 01:29 AM
99Bluz28's Avatar
A new set of good shocks(Bilsteins, or Koni SA's), and keeping the tire pressure around 30-32 psi will go a long way to improving the ride quality.
