torque arm relocation setting
Old Aug 31, 2013 | 08:14 PM
nomasterase's Avatar
Default torque arm relocation setting
I did a search but i was unable to find the info i need. I purchased a torque arm relocation bracket from umi during the labor day sale. Wondering if theres a way to determine which set of holes to start with for the forward torque arm mount? I would imagine this needs to be set first and then the driveline angle. Thoughts?
Old Aug 31, 2013 | 11:36 PM
UMI Sales's Avatar
Yup. Thanks for the purchase.
The lowest set is rarely used. The middle two sets are nearly stock. The top set changes the instant center just a but for more forward traction.
I'd start on 2 or 3 unless you're drag racing a lot then got to four.
Driveline angle is last.
Have a great weekend.
-- Ramey
Old Sep 1, 2013 | 08:07 AM
Thanks for the input Ramey. Sounds like i may start with the third hole and see how streetable that is
Old Sep 1, 2013 | 10:44 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I just did this. Went with the 2nd hole from the bottom.
Old Sep 1, 2013 | 11:48 AM
Did you try the third hole from the bottom dr whigham? Any reason not to use the more drag oriented setting?
Old Sep 1, 2013 | 01:21 PM
dr_whigham's Avatar
The Scammer Hammer
I've got Spohn solid motor mounts, and we all know they raise the engine approx half an inch... I thought to give it a shot and see what it did at the second hole from bottom, but only because I'm stock ride height.
Took the car to 80mph, with stints at 60, 65, 70, 75... No vibration or anything. Seems to like it so far. I'll delve deeper into it though once I get the rest of the suspension in, which will be UMI on-car adjustable LCA's and PHB.
Old Sep 1, 2013 | 03:30 PM
I did energy suspension poly motor trans and torque arm mounts at the same time as my tsp 1 7/8 headers and ory. Already had founders lower control arms lcarb's and on car adjustable panhard bar. Caught the founders adj torque arm on initial sale and couldnt resist umi's labor day sale on the relocation crossmember
Old Sep 1, 2013 | 03:48 PM
dr_whigham's Avatar
The Scammer Hammer
Can't beat UMI's customer service either. Always great to get on the phone and talk to folks that know, and have RAN these parts.
