Sway Bar or Air Bag???
Hey guys, I am having a little trouble spinning every now and then on launch. I have an adjustable torque arm, sub frame connectors, auto tranny, adjustable lower control arms, and a 9 inch with adjustable lca brackets. My lcas are in the bottom hole and I believe is set correctly. I am cutting 60' times as low as 1.62 with 255 60 15 MT drag radials. I race mainly at a track that is not prepped well and if I dont do a killer burn out I will spin some. The other track that I go to some hooks very well and I dont think I could make it spin there. I am wondering if I couldnt help my situation by putting in a drag sway bar or an air bag in the rr . I am wondering if this would help me with consistency as well? Any thoughts?
Sway bar may help a little, but it sounds more like an issue with the lack of track prep, mixed with the drag radials. I could go the route of a bunch of radial guys and tell you to drop a bunch of $$ into some DA rear shocks, but truthfully if your track doesn't provide a good surface you will be chasing your settings around and spending extra money. If you want to keep going to that track you either need to budget alot of $$ for tires, or get a set of slicks to overcome the track conditions.
FWIW..My 3rd gen had cut 1.56 without a bar, on slicks (has one now).
LS1Tech Premium Sponsor
Feel free to give us a call for honest, experienced advice. MWC sets up the suspension for the fastest stock suspension f-body cars in the country.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Thanks for the input. Ive done a ton of searching but cant find where anybody said they had my problem and solved it with a sway bar or air bag. I have a set of cheap drag shocks on the back but am running stockers on the front. I may just get me a set of slicks after these drag radials wear out.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
