brake pads so small
Old 09-16-2013 | 06:53 PM
m1a2d3's Avatar
Default brake pads so small
i just bought some hawk brake pads they look so small. most everything i own is a heavy duty truck and these thing are tiny. should work better than stock but i was blown away by how small they are.
Old 09-18-2013 | 05:33 PM
m1a2d3's Avatar
okay the pads i got were for the rear. the fronts came yesterday dont know what i was thinking since there was only one set. the fronts are alot bigger than the rears. got the strano brake package 2 has anyone run this setup and did you like it.
Old 09-18-2013 | 07:42 PM
camarokid91's Avatar
The HPS should be a lot better than stock just make sure you bed them. I run HPS or HP+ in the front for racing and autozone 22 dollar pads in the rear. My car gets axle hop under hard braking because the factory GM brake proportioning is like 50/50 which is terrible.
Old 09-19-2013 | 06:25 PM
m1a2d3's Avatar
when you say bed them what do you mean. thanks
Old 09-19-2013 | 07:07 PM
dr_whigham's Avatar
The Scammer Hammer
"Bedding Brakes"
5 moderate to aggressive stops at 40mph to 5mph w/o letting the brakes cool or w/o a complete stop. Then do 5 moderate stops at 25mph down to 5mph and let the rotors cool after each time.
Old 09-19-2013 | 08:06 PM
Correct
Here are the instructions off hawks site:
Bed-In Instructions
1.After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
2.Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
3.DO NOT DRAG BRAKES!
4.Allow 15 minutes for brake system to cool down.
5.After step 4 your new pads are ready for use.
Old 09-20-2013 | 05:27 PM
m1a2d3's Avatar
thanks first thing i did was throw the instructions out. i know the rotors also have some type of coating on them that wears off and the rest of the rotor wont rust. maybe ill call strano and ask about how to break them in. or if i have to ill read the instructions. thanks
Old 09-20-2013 | 08:02 PM
dr_whigham's Avatar
The Scammer Hammer
No reason really to call and bother Sam. Two instructions have already been posted, both almost the same. That's simply how you do it.
Old 09-21-2013 | 08:31 PM
m1a2d3's Avatar
i was more wondering if the rotors require something different since they have a coating that has to burn off. went to the hawk website and couldnt find any special instructions. dont want to bother anyone just trying to do it right the first time.
Quick Reply: brake pads so small
