D-I-Y ABS Delete
#64
So I found a company that makes a block exactly like he used above:
http://www.prbmachining-absdeleteman...talog/i35.html
#66
http://www.prbmachining-absdeleteman...talog/i34.html
#69
No, he sells a non traction control block too that works with 3 or 4 channel abs. The block comes with a plug if using a 3 channel set-up. I have it on my 98, real nice piece.
Thanks from my part to for the link too.
The break fluid run the same direction in this block like in the factory abs block. The slp line lock should work good in this case.
#70
Yes, any line lock will work. The block ports are labeled just like the factory one. Very small & compact. The only thing I didn't like, is that it will not mount to the factory abs bracket. You will have to make a bracket or just not use one at all. I'll get a pic of mine tonight. I made a bracket for it & running a line lock with no proportioning valve.
#71
now im a bit torn, between running this block or just using the wildwood p-valve with the outlets on it, and running all new lines. Im swapping to the ctsv gen 2 brakes so im gonna need a valve and I want to hide quite a bit of stuff so im , but wanted to run some new lines as well since Im running a umi k member and 9" rear nothing is as flush as it was when she was stock.
#72
#73
How you like your car brake with no proportioning valve?
#74
#76
