Problem with rear shock replacement
Old Nov 18, 2013 | 08:02 AM
rxrom's Avatar
Default Problem with rear shock replacement
I bought rear bilstein shocks. Took it to a shop to have installed. The bolt on the top of the shock is rusted to the shock. The shop won't try to remove the bolt because they say they need to use a torch to cut it off. Because its accessed from the interior it's a liability.
Before I take it to another shop how can I get the top bolt off. I sprayed it with wd-40. When I try to turn it, it turns with the shock.
Old Nov 18, 2013 | 08:46 AM
97FormulaWS-6's Avatar
From: Land of the Mormon's although I'm not one of them
There should be 2 flats on the end of the threads; that's there to hold the "bolt" while you crank off the nut. WD-40 is useful as a screen door on a submarine when it comes to breaking rusty bolts loose. Sea-Foam Deep-Creep works the best that I've found in my years of working on rust-buckets.
If that doesn't allow you to hold and spin the nut off; then use a vice-grips to hold the threaded part; and a hack-saw to cut under the nut (This is what I've had to do before to a few cars). No way I'd use a cutting torch inside the car; I can see why the shop won't do that.
Old Nov 18, 2013 | 08:48 AM
MeentSS02's Avatar
Kleeborp the Moderator™
I've read about this, but never tried it:
Get some beeswax (you can find it at hobby stores usually), heat the nut/bolt/threads with whatever you have available, like a lighter (being careful not to catch your car on fire), and let the wax melt into the threads. It'll work just like any other penetrating lube out there, but some people swear it works better than the spray type lubes.
Other than that, find your favorite penetrating lube and let it soak for a while.
Old Nov 18, 2013 | 12:59 PM
rxrom's Avatar
After wd40 sat for an hour. Vise grips and wrench got it. With sides are loose
Thanks.
Old Nov 18, 2013 | 04:39 PM
AJUSA.com's Avatar
In the future I'd try a different shop if this one couldn't even figure out how to get a shock bolt off without burning down your car...
Old Nov 18, 2013 | 05:39 PM
leadfoot4's Avatar
I agree!!
To the OP, if you still haven't gotten the old shocks off, AND you don't want to re-use them, here's something we used to do, to get "old style" front shocks off (which are somewhat similar in mounting, as the 4th gen rears). Put a deep socket on the top nut of the shock. Stick a long extension in the socket, then work the shaft of the shock back and forth, until the top part of the shaft breaks...
rxrom's Avatar
I'm trying to find a good shop in my area. It's harder then I thought . Most shops want you to drop of your car and come back after a phone call. I like to watch the work being done.
Old Nov 19, 2013 | 11:25 AM
rxrom's Avatar
My shocks are installed. I went to a local shop. Les then an hour $100. I'm happy. Will order front shocks next (bilstein)
