Hotchkis LCA's....
Have a set of Hotchkis rear trailing arms/panhard rod on order. Didnt have enough $$$ to get a 12 bolt so i have the stock 10 on the car still. Just curious if you all think i will blow the 10 bolt w/ sfc's and the hotchkis rear? I can come up w/ the money w/in a month if i absolutly had to but idealy wasnt looking to get the 12 bolt until next season. Can i go that long w/ maybe a race/week for the summer? Thanks all.
it all depends on what tires you run, if you have slicks and launch at 5,000, then the 10bolt wont last long, but i have 10 bolt with 4:10 gears and use dr's and have had no problems for two years and several trips to the strip, you should deffently be ok if you have stock gears
