Mid Install Clarification Needed UMI K Member
Ok so i finally got my stock k member out if my car and had one quick question before the new umi tubular k goes in. My question is do the washers go between the frame and the k member or between the bolt head and the k? Ive searched and everyone said that the washers must be put in exactly where they are zip tied and when i opened up my box one was siting on top of the k member and the other was hanging under. So id love some clarrification from someone. Thanks.
Sorry for the time its been between starting the thread and this post. Well i got the new K-Member in and it looks awsome and i should be able to access and work on my engine easier now. Like others have said the washers are supposed to go between the frame and k member cause i called umi to double check and they said to put em in that way. And i used a jack with a block of wood under my oil pan. Its probably not the safest way but its cheaper than buying/renting a engine lift. Now all i gotta do is get my front LCA's back on and go get it aligned.
