Lower Ball Joint boot
Should I be replacing the UBJ as well at this time or am I okay if it feels stiff and isn't leaking. The wheels had no play (while in air) before I removed them. I'd like to save $$$ if possible as other aspects of the winter project are starting to nickel and dime.
I don't want to look at my receipts.
Here's a tip, if you're using a b/j press on the lower b/j's. Leave the LCA bolted to the car, that way you're not fighting to keep the LCA from dancing all over the place as you're tightening up the press....
http://www.partsgeek.com/catalog/199...brand=mevotech
Moog joints are usually pretty good. But just a heads up, they make them slightly oversized to fit tightly in arms with worn holes which means they can be quite a bear to get pressed back in. I froze the joint and heated up the arm to help it go together a slight bit easier.
