Know nothing about brake line fittings. Help me install this ole line lock and PV!
95 Trans Am. I got this used SJM LL and ABS delete kit for next to nothing, and I have no idea what fittings I need for the following pictures. Everything is good from the Master Cylinder to the LL and PV, but after that no fittings were given to me. I know I will need a double flare tool, but what size fittings do I need to connect the 2 front brakes, and the one rear 1/4" line?
Got the fittings from Napa today. Was easier than I though. Now if I can flare the stock lines while they are in the car Ill be set. Im not even sure if that's doable??
