Bought some used Konis.. A few questions
Found some rear adjustable (8241) yellow Konis on craigslist that were pulled from a car that was parted out. Not sure of miles, and they're not the prettiest but for $75 for the pair, it can't be much worse than my stock ones at 75k miles.
I was going to put them in a bit ago, but noticed
1. I don't have either adjustment **** (was planning on just using a wrench if that'll work)
2. The shaft doesn't 'return' instantly like I thought shocks were supposed to. Maybe this is normal, I don't know, but after I left them outside in the garage for a bit and came back, they seemed to be slowing returning.
Maybe it's because they're cold in the garage? (~30-40 degrees) If not, and they're toast, I was thinking I could just find a place to re-valve them for me (no idea how much that costs)
*******The first picture shows the shaft in.
LS1TECH Sponsor
What pushed the rod out is gas pressure. If they didn't move they'd be de-gassed and that's not ideal. They are, that's good. They are cold which makes the oil thick and the seals stiff, which slows the speed they extend. But they adjust rebound, which is how fast they extend.... more rebound damping = slower which to some degree is what you want.
I don't know if they are good or broken by looking at them. They are likely ok if the adjusters turn and stop as they should.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Like sam said, if the adjusters stop and don't spin forever then they are likely good. If they don't then junk them and buy new ones. Rebuilding konis cost $115 + parts and the rear shocks can be bought new for about $200 per. If they were fronts that would be another story.
LS1TECH Sponsor
Less than $200 per. I'm @ $184.99 each right now. And *IF* Koni does their Shock Value sale again, well they'll be even less. PLEASE NOTE I DO NOT KNOW IF THAT IS HAPPENING AT THIS TIME. And there are even less costly options, the 3rd gen rears are currently $130 each.
Definitely does not pay to rebuild them.
__________________
LS1TECH Sponsor
clockwise is less.
__________________
LS1TECH Sponsor
Vice grips?
__________________
LS1TECH Sponsor
Other people have taken to selling them, but I was the one that found they worked (I won National Championships with them on the rear in fact) and first offered them as a slightly more cost-effective, if not as flexible, an option.
__________________
I tried that but didn't want to force anything. Is the whole rod that's supposed to spin when you adjust it, or is a wrench needed to hold the top yellow nut in place and spin the small flat piece? If so, that didn't want to budge (or should I install, then adjust?)
Here a link for the adjuster if you want to purchase one http://www.koni-na.com/apparel.cfm?level=1.
And short vid to see what part is adjustable
LS1TECH Sponsor
These are some of the reasons new isn't always bad. Known good shocks, the adjustment ****, and instructions all come with them.
I can't hold them, I can't feel how the adjusters are, I don't know what to tell you unfortunately. There is a stop that is pretty solid at the soft end, less solid but there at the stiff end. Turn the adjuster, hold the shock shaft so it doesn't spin. If it won't turn either way, well you have a problem. It might not turn one way if it's already full soft or full stiff.
__________________
LS1TECH Sponsor
only to the original owner.... you aren't him.
__________________
